Direct fit?
yes a 2.5 will fit to stock setup. Question is since its off ebay will it fit period. Check the peoples reviews that have bought them to see what they say. I know I bought an ebay downpipe for my 90 and it wasn't even close to fitting I sent it back and made them send me a return shipping label not my fault it didn't fit.
Thanks for the info man. I appreciate it. I'll check the reviews so I don't make any mistakes.
Oh... And another question.. Would getting a down pipe like this one delete my cat? If so is there any risk involved in that?
No it will not delete your cat. more than likely since it is off of ebay you would have to get a straight pipe "test pipe" made to fit to your existing exhaust. You have to remember is prolly designed by the Chinese but its just steel its either going to rust really fast or not. Like I said hopefully someone would have commented on the reviews but I highly doubt it makes a perfect bolt of to your stock cat brotha
If you ask me delete the cat you get better flow. then you have to do the o2 sensor eliminate mod for 2g and you should be good. better flow means more power
Nothing a machine shop can't fix. Or just get a file and go to town with it. I've had my exhaust for 6 years and though there are small surface rust spots all over due to it being cheap stainless steel, I have never had issues with flanges sealing when used with gaskets. YMMV.
I've been running an SRS "eBay" full turbo back for awhile now with no issues.
  • Wanted 6 bolt NT water pipe
    • chrisman287
