Different brake rotors?
ZLODEY
85
Sep 9, 2006
Vilnius, Europe
Is it truth that from 1995 till 1999 GSX's had a different brake rotors? I always thought they are the same, but CAPS shows me different spare part numbers... How could it be? I'm goint to replace stock rotors with brembo replacement. I'm a bit confused :confused:
I know that the FWD rotors are different from the AWD but all the AWD are supposed to be the same. Maybe CAPS is confused. Hope that helps you, Keith.
95-97 are the same, 98-99 are the same. No idea why that's just the way it is.
Do you know what is the difference between '97 and '99 then? Size? I thought all GSX rotors are the same size...
all the same size, fwd are smaller.. they probably changed the part number(.. GM does this all the time..new numbers for parts that dont change..
Wrong. The front rotors for an AWD from 93 to 97 are 276mm, the one from 98 to 99 are 268mm.
