DIfferences between FWD AWD pressure plates, clutches and flywheels
Gst18
147
Oct 3, 2005
Madison Heights, Michigan
I was just curious which can be used with which and from what years to what years they differ.
Thanks for any inputs.
Any 4g63 clutch/pressure plate will bolt up to a 4g63 flywheel. AWD flywheels have a smaller outer ring gear than the FWDs, so if you try and bolt up an AWD flywheel to a FWD vehicle, your starter will not engage. Also, pre mid-92' cars had a 6-bolt flywheel, where-as the late 92+ cars had a 7-bolt flywheel. This must match or the flywheel will not bolt on.
In short AWD flywheel for AWD car, any 4g63 clutch/PP for any 4g63 flywheel.
