Difference in 1g/2g clutches
RossY
627
Sep 27, 2002
Canton, Ohio
I have a 6bolt motor and a 2g tranny. My question is whether there is a difference or not in the 1g and 2g clutches? Are they interchangeable or not. Im wondering this because if they aren't then I want to make sure that i get the correct clutch.
Thanks
The clutches are the same; the flywheels are not. So you say you have a 6-bolt, meaning you have a 6-bolt flywheel. The clutch itself is the same between the gens, though, so it should be fine.
