Die threading ebay B&M short shifter clone
Nayr747
248
Feb 10, 2004
somwhere, Nevada
So the threads on my ebay clone B&M short shifter are not the same as stock (10mm x 1.25). I thought about just hacksawing the threaded portion of the SS off and using a die to put the correct threads below it (which would also lower the shift knob :D). But the area below the threads is wider in diameter than the threaded portion, and to my knowledge the part you're threading has to be the correct outside diameter to use a die on it. Is this correct? Also, it gets even wider below this and the stock shift knob wouldn't be able to get on the SS since the bottom of the knob goes below the threaded portion and is not much wider than the threaded portion. So I have no idea how I would get the SS to the correct diameter. I don't have a lathe or anything like that.
So instead of all this I thought of something else. I could "fill in" the threads on the s.s. with JB Weld and then use the 10x1.25 die on it. But I don't know how secure this would be. Anyone have any advice?
1. Bench grind the shaft to the right diameter. Close enough is, in this instance. If you don't have a bench grinder, get a $30 from anywhere.
2. Don't bother with the JB Weld. You can go ahead and cut the new threads amongst the old ones. The amount of stress you can put on the shifter with your arm won't be enough to get them to let go.
3. Instead of cutting the threads in the stick, run a tap into the much-cheaper shifter knob. You can also drill it deeper and run threads all the way in.
4. Use a Honda knob. There's 13.6 million different designs, and they're cheaper than cheap. Once you start driving with a smaller shifter knob, you'll never go back.
