did i order this turbo right?
ssk8terboy411
Nov 16, 2004
Walnut Creek, California
i ordered the big 16g with "external wastgate, manafold mount" did i order it right or should i have ordered it internal? does it matter , is this going to make it not able to bolt on to my 91 tsi awd? i orded this off of slowboy
well wut setup , when you go to the slowboy site there is a bar that comes down that says:
internal gate 31mm std.
internal gate 34mm(+60.00)
manafold mount(external)<--------i ordered it with this one
o2 housing external gate
i thought it meant just manafold mounted like the 14b? did i maybe readthis wrong?
It means that they will weld the internal wastegate shut because you have told them that you are going to be mounting an external one on the manifold.
You might want to call them and get this fixed....or buy a manifold with a flange for an external wastegate and external wastegate because you will now need them.
-T
