pauleyman
DSM Wiseman
- 11,705
- 5,551
- Nov 19, 2011
oklahoma city,
Oklahoma
I wrote this years ago and thought I would share this here......(9/30/2023 thread has been updated multiple times over a decade. Please read the WHOLE thread)
These thoughts are of course, my opinion. Your results may vary.
I see a growing trend of folks who can't diagnose anything. Doesn't matter if it's a car or a toaster, they simply do not know where to start. Maybe I'm weird and took everything apart when I was growing up. I would think that to be able to diagnose what is wrong with something you should have some amount of common sense and a basic understanding of physical things, mechanical relationships and maybe some understanding of physical phenomena. In the interest of safety I'll mention a few
1. Don't put your finger close to moving parts.
2. Does the part look hot? Don't put your finger on it.
3. Did you just apply heat? It's probably still hot, don't put your finger on it.
If you are in the least puzzled or didn't know the above statements then at this point you probably have no business diagnosing mechanical things. Maybe you're more into biology and can tell me why my blood pressure is high.
Anyway, let's talk about diagnosis.
You have some mechanical/electrical item. We'll use the term broken but that can also mean it simply isn't doing what it's designed to do. Be careful here as how do you know it isn't working? Can you physically see it? Did you measure it? Or do you just know the mechanical item you are looking at isn't functioning so you ASSUME a particular item isnt' working. So now then.....
Start off with what you KNOW. Not what you think you know but what you actually know.
Your tire if flat, well how do you know? Duh you can see it.
There are tons of other things you can't see so how do you KNOW it's wrong? The best way is to measure something but if that's not possible or practical we can certainly gather some data based on other facts. There may be some assumptions along the way but no pure wild ass guesses.
Let's rule out some items
Was the item working 100% before it broke? No? 100 other things could be wrong. Good luck on your search.
Yes? Great maybe we can focus on just a few areas then.
Did you just work on a particular item/area? Yes? Start there first.
Did you see or do you see something physically wrong and you are certain of what you see? Large holes in the sides of formerly solid items are a good indication. Yes? Start there.
The point of all this talk is to gather what you KNOW so you can forms a decent diagnosis.
Try very hard to leave subjective things out of the discussion.
"It's making a funny noise" is largely a subjective statement.
"The sound the item makes has changed pitch and I have never heard it sound like that". That is much more objective and descriptive.
This analogy works fine for most diagnostic issues.
My toaster doesn't cook the toast all the way.
Did it work yesterday? Yes?
It's obviously plugged in or it wouldn't cook at all...so rule that out.
Did you check the control knob. No changes? Did you try and turn it up anyway? Still doesn't work?
Can you see the heating elements heating up?
Get the point? Look at what you KNOW.
Gather some data on what you're looking at. Is this a complicated system? Large generator perhaps? I hope you arm yourself with some technical data, specifications etc. There are usually manuals for these items, hint hint. Do you always need a manual? Of course not. That is entirely dependent upon your memory and skill level of items over time. Are you likely to remember the proper torque setting of a head bolt on a 71 nova? Not likely, that's why we look stuff up. Can you remember the spark gap on the same car? Yeah, you just might.
Even if you can't diagnose something yourself you can gather objective data and relay that to people you know or gather information form technical publications which may point you in the right direction based on what data you have gathered.
Specifically on the subject of DSMs I can tell you this. 99% of the things I have done on these cars was largely as a result of something breaking, me reading on the subject and me doing the work. When the cars were new there simply wasn't as large a pool of people to ask. I couldn't afford to pay somebody to fix it so I did it myself. I did have a good understanding of cars already so that helps. My first timing belt job, transmission rebuild, strut change etc were all done with nothing more than determination, hand tools and a shop manual. My only advantage to somebody new is I have see the same problems over and over and over so it makes it that much easier to diagnose certain things as we can make certain assumptions based on prior experiences. Again, no wild ass guesses but instead educated guesses based on past failures. Am I willing to share? Of course..... that's what we do
