Dejon intake?
clean96GST
462
Jul 14, 2008
Arlington, Washington
So I picked this up pretty cheap with a 3" K&N, but it only has one nipple on it and no place to recirculate the bov. What would I have to do to get this on my car? I'm guessing deleting a lot of stuff, a maf adapdor, and maybe welding on a place to recirculate my blow off valve? Is this even worth it?
You can either weld a nipple on it for your bov recirc tube, or get the supporting mods to vent your bov.
Making that work with the 2g MAS will be fun. Doable, but that's what I would worry about the most.
Yeah after putting them side by side I was thinking the same thing. I'm doin the tranny in the car right now and I'm putting in a new radiator and a front mount before it gets driven again so if it's not to expensive I might run a GM maf, does anyone have links on how to do it?
If your going to run a gm maf, use the pipe you have, and you won't need to recirc using the gm maf.
well you dont need all those hoses. you can purchase a gm maf, maft and this will work perfectly, and block off all those hoses! if not you will do a lot of work to get this to work with the oem mas. good luck!
Nope, and you can vent your bov. I have a 3" gm maf if you want it, youll just need the maft or dsmlink. PM me if interested. The cheapest route is the gm maf and translator.
