Dejon intake question
goshred005
Sep 30, 2004
honolulu, Hawaii
will the 1gN intake fit if you still have the stock intercooler pipes? cause i know the 1gN is longer than the stock intake. thanks
no use starting a new thread..soo.. which dejon intake will emulate the stock 2g intake???(ie fits t25 and isnt longer than the stock intake)
I had my 1gN pipe in mine with the stock ic piping. If you are patient then it will fit. Put the filter in first as close to the fender as possible. Then attach the intake to the turbo. Then connect them. Do not try to put it in as 1 piece.
Raph go to www.dejontool.com
you know what would be a better intake and fits with the stock mas and goes onto your t25, 16g, t28? go to forced performance and check it out. it comes with a coupler that goes from 4' to 2' so it mounts to the t25.
