Decided to go turbo
Why not upgrade the 4g64 to turbo? I don't know one person that has regretted turboing their car. I guess the question is how fast do you want it to go?
If you're talking about that spyder gs, you have a 420A motor. Most people will recommend to sell the GS for a 4g63 (GST/GSX/or Talon) if you would like to tinker with a turboed DSM.
WTF
The Spyder GS came with a 4g64 not a 420a
And boost the 4g64. They take boost pretty well in stock form. And the 4g63 parts bolt right up so its a fairly straight forward process.
Id upgrade the head of the 4g64 to a 2.0 4g63t.
Id want to push atleast 400 horses
You have to rebuild the engine and go fully forged internals with special hybrid pistons to go dohc with a turbo. Using a 63 head gives a 64 a cr of around 10:1, much too high for turbo use on cast pistons.
Your cheapest option would be to buy a running donor 2g turbo car, and swap over the complete drive train and engine/ecu harness and ecu. This is the route I went
Had no idea the compression ratio went that high with the head swap. Much higher than 8.5:1 and even higher than 7.8:1 LOL.
Probably why they're rated at 250Hp when you do a "stock" swap.
:ohdamn: :rolleyes:
Crazy compression with a 4g64.
Yeah ill probably find a donor 2.0 and do that, by the way, why do you need to change the harness?
Are there that many different sensors?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
