data logging cables (pic) what do i need?
jameswemm
86
Feb 16, 2005
hope mills, North Carolina
i recently bought this cable off ebay.today i got my pda (palm m125)in the mail also bought off ebay.got palmenstein loaded and went to radio shack to get a gender adapter from usb to db9 .the guy told me they did not make one and it would be impossible to hook it up.anyone know what i need to make this work.
Yeah that looks like the same cable I have. It's just a standard hotsync cable, you dont need a usb adapter. Also palmnstein is really a horrible piece of software, if you can save up some cash and get pocketlogger it would be worth it
whats the difference between the pocket logger and what i got.(palm m125 -palmenstein and looking into the mmcd.)jott5555 is that your ebay listing.
I purchased the same thing as well...and have a question on getting it hooked up on my DSM.
about 3 years ago I had the TMO logger and it was real easy to install and use. One connection to the fuse box, then the othre just plugged into the diagnostic port.
This cable however has 3 plugs, and I know one goes to the fuse box like my TMO cable...but where do the other two connect to the diagnostic port at? Any help anyone!?
Nope, unlike the logger cable you got from TMO, the new one is passive and has no power connection. Ask the seller which pin goes where. The really cheap cables will have two connectors that are common and those go to pins 10 and 12 (bottom right) with the left over connector going to pin 1 (top left) on the DLC.
Steve
  • Wanted 6 bolt NT water pipe
    • chrisman287
