data logger cable
brian9397gsx
1,551
91
Apr 28, 2008
sioux city, Iowa
i recently was in the market for a cable after searching i decided on a pocketlogger but unfortunantly they are discontinued. from the advice i have seen i decided to get this cable
eBay Motors: USB VAG OBD-II Scanner Scan Tool Cable KKL for Audi VW (item 150327785938 end time Apr-20-09 02:31:11 PDT) now the problem i have is my hotsync cable for my palm is a serial db9. after searching i have not been able to find an adaptor to connect the two. is there anyway to combine the two cables i know the 9pin has 9 wires but i am unsure on the usb any help would be very much appreciated thanks for the time
Is this for your 1g? If so, it's not OBD-II. If you're good at soldering you can build you own from parts found at RadioShack or other electronics supply stores using this diagram:
no sorry this is for my 97 gsx sorry about that
yeah that cable has been discontinued. it was my first choice
this is for a 2g
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
