Dashboard Gauge cluster wire routing ideas anyone?
Norcalgsx707
564
Jun 28, 2012
lake county, California
So this is a first for me, I just recieved my 2 gauge dash pod cluster and was wondering how to route the wires, I just bought a Used Glow shift boost gauge that will go in the left pod (the wiring to that will be a first to).Anyways should I just make holes in the lower plastic dash piece? Anyone got any pics I already have my wideband set up to run off my radio wires its just getting the wires to the right places.
If you take off the lower dash panel under the steering wheel you'll be able to see all sorts of room. It is held on by 2 10mm bolts on the bottom and two bolts that are behind plastic covers (one on each side of the steering wheel). When I did mine I ran the wires from the right gauge to the left gauge and then went down to the fuse box from there. If you have any questions pm me and I can put pics up.
  • Wanted 6 bolt NT water pipe
    • chrisman287
