IAT sensor wire routing
Adiya Akhil
Sep 26, 2011
houston, Texas
1997 Mitsubishi Eclipse GS
I followed the test procedure in this video
IAT or Intake Air Temperature Sensor Testing - YouTube
The ground tested good 12.6 volts
Then on the next test i get 18-22 volts it jumps around (engine running). So according to the video my ECU is bad (local Pepboys also said it was bad) so i replaced the Sensor first then the ECU and still get a p0113 CEL (Intake air temperature sensor - high voltage). The only other thing i can think of is the wire is routed to close to the ignition coil. What do you guys think?
420a Iat wire route - YouTube
  • Wanted 6 bolt NT water pipe
    • chrisman287
