Dash Lights went out
Busa_DSM
Nov 24, 2004
Bentonville, Arkansas
I have done a search, I looked in the chiltons and haynes manuals, and looked in the car. Could someone please tell where the fuse is for the dash lights in a 1G (92) GSX. Can't find it. Thanks in advance.
Don
hehe, its ethier in the engine compartment (most likley) or on the driver side door. get long nose pilers and jsut check for the fuse, also a common mistake is a bad radio ground from installing an aftermarket radio.
That was it, I dunno why they put a dash light fuse under the hood, but that was the prob.
Don
i have the same problem, only in a 96 spyder 2.4L. my dash lights are completly gone, along with the climate control lights. i've checked all my fuses, and none of them are blown. the hot wire crossed with ground on my ashtray light, and caused my lights top flicker and go out. did i possibly fry the wire? or a fusible link? i've narrowed it down to those two sources, but can't get any further.
Did you actually swap the fuse with another one to check it? Fuses can be blown while looking like they're not.
