Dash lights..Cluster lights
Levesque
152
Apr 19, 2009
Chicoutimi, QC, Canada
I cant seem to get these to work...
Flashers , High beams , 4 ways , low fuel.... all work
But the damn speedo and tacho lights and all the HVAC lights dont work...
Thought it was a short. Pulled the Aftermarket radio, WOW like 10 exposed wires... Taped them all up and was like It should work now. NOPE nothing.
The lighter is removed but its a plug so shouldnt have to worry there nothing is exposed.
All the fuses are good.
I'm getting .93V on the Dimmer plug....( not even sure I tested that properly LOL)
^^ that seem right ?
All I can think of now is that its the Dimmer switch it self...possible?
Pulled Cluster bulbs are good even switched them with the working flashers to see if that was the problem.
BTW... Reverse Lights dont work either... not the fuse also.. Bulbs look good.
tail lights and all other lights work.
roof lights work also
Thanks for the help guys.
Cant I just pull the wire that plugs into the dimmer and cut both grounds and connect them and have constant dash lights with out option to dim period...?
Problem fixed #### the dimmer connected both grounds works now.
