damper fork
68442
639
5
Oct 14, 2007
Des Moines, Iowa
On my 97 awd auto the lower bolt on the damper fork is seized. So I am unable to remove the strut. Looking at it I have a few choices. One is to cut the head of the bolt and the end off and drill it out and get a new bolt, might be tough to drill straight. 2nd is bust a ball joint loose and remove fork and replace with used or new fork and ball joint. Number one is way cheaper of course. Any suggestions?
I agree. Swing by NAPA and get some BG In-Force Penetrating Oil. Then try it by hand. If that still doesn't work then get an impact. Since it sounds like a virgin bolt, clean up the head a little with some brake cleaner and a rag so you can really get a good grasp on it.
But if you have to cut it, go from behind. Because I know that the fork compresses around the strut to hold it, and there should be a gap to get a cutting tool in there to cut the bolt holding it together. I wouldn't recommend doing this at all. But if you are absolutely on your last option.
After breaking 1 of the bolts for the rear control arm, and knowing the other was going to break.. I had decided no more.. I went and bought a compressor immediately and removed the remaining bolt like a snap.
A $200 air compressor that came with an impact gun was the best mod I ever did.. everything seems to take half as long as it used to... I swear quite a bit less, and my knuckles don't get near as bashed up.
That bolt that broke is the last bolt I've had to easy-out since I got the compressor about a year ago.
Let the impact try to drive it in a few taps, then try running it out. Do this repeatedly, in and out. You just have to get it to break free. My 450ftlbs Sioux breezes through everything. I have never even considered getting a larger (and slower) impact.
Just keep messing with it. PB (or whatever) and impact. Eventually it will come out without breaking anything.
  • Wanted NA 1ga running and driving
    I'm in the market for a N/A 1ga Dsm preferably running and driving that's manual. no preference...
    • Nii
  • For sale 2g 7 bolt engine build parts and mounts,
    New lowered prices on everything!
    • beegeezy
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
