Daddy's Zoom Car
Bought in 1997, still the daily driver
rdeis
116
40
Feb 28, 2013
Falcon, Colorado
This is the Build Thread for Daddy's Zoom Car. Reply below.
I've had this car forever- sorry about the empty build thread, I'm just getting the profiles and things set up so I can get serious about tuning it properly. Goal is a 400 or so street car that's even more fun than it was back in the day without getting too fiddly to take care of. (BTDT, I wasn't cut out for hobby racing)
The kids that named it are all grown up, so I've got some resources to finish the project now.
Nice to see another Colorado DSM getting revived. If you aren't already a part of it, join the Rocky Mountain DSM group on facebook. Pretty active over there and already have meet-ups scheduled for the year
Thanks, I’ll look! I’ve still got my membership card from the CoDSM days, but I was never an active racer so I just hung around with the big names and tried to learn from Salmi and Norm and Hal. There’s my name drops for the day! :)
Wow ive not heard those names in awhile. Where are they? I briefly owned Hals 1g dsmlink beta car. It was a serious beater with no 2nd gear.
Unfortunately I don’t know. I lost track of most of the club when we moved from Boulder to Cos and little kids pulled me away from cars for a while.
Last I saw John S he was selling the 2litre and starting a monster Supra build. Fairly certain I saw the 2litre listed for sale again a few years ago but wasn’t in a place where I could pick it up. ):
I probably haven't spoken to them in 20 years. Maybe when digest shut down. Don't remember. I think I bought hals laser early 2000? Don't remember its been so long. I ran up to Denver from okc and back in one day. Drove back with no 2nd gear.
Those were good people, for sure, and the club was smaller and more focused. Fun to hang around with people as everyone was first figuring out the stuff that "everybody knows" now.
While chasing down boost leaks around the injector seals, I figured the injectors are old and maybe a little leaky, so this seemed like a good opportunity to upgrade "while I was in there". (Famous last words...)
I've got new seals and the leaks are gone, yea! Took me a fair amount of time and study to get the mostly idle stable with the new FIC 775 high Z, but I think I'm there.
First big help was the InjBatteryAdj table in the Direct Access tab. It seems that the new injerctors are far more sensitive to battery voltage changes than my low-Z 660s were, so small rpm changes changing alternator output and various electrical draws (radiator fans..) turning on and off were causing problems.
FIC provides values for all their injectors here: FIC website, but the tables don;t cover 1G voltages and fule pressure so I had to do some math to get correct values, and that made a huge difference. New values are:
72.8118
91.7541
121.0885
140.8384
160.7143
190.9456 <- this one is suspicious, I need to check it
The FIC guys suggested -35.3% and zero deadband, but that didn't work very well.
Using the ECMLink's built in calculator and ecmlink data tables I got about a -40% and set the deadband to 300, and the idle is much better. Haven't had a chance to drive it too much yet because of an unrelated problem, more on that later this eve.
Woot! another former CODSM member. I never did get a chance to meet the guys you named, but saw them around the forums a lot. Carl Morris, Ryan Larson, Erik A., Jake Latham all helped me out at some point or another. I'm still displaying a CODSM window sticker that I picked up at one of our meets! Oh, the good ol' days.
The Rocky Mountain DSM Facebook group has been very active of recent, along with meets and cruises. Hope to see you both out there sometime
I happen to have some extra time so might be something to look into. Sorry to hijack the build thread. There's another thread around here to discuss details I'll go find.
I just purchased these FIC 775s for my car, it's a 2g with 6-bolt swap.
Curious how you have been coming on the tune and if you have more firm numbers for global/deadtime/latency considering your voltage fluctuation issues.
Car went down with a multi-part clutch failure, but it's back now! All new hydraulics and a new clutch disc from Southbend. I don't see them on the vendor sites anymore, but I had the part number for the clutch in my records. I called the guys there with my old part number and they had a new disk in my hands in a few days, very nice!
I also took the time to helicoil a couple of oil pan bolts that had striped and swapped out the oli drain line from the turbo for a set of AN-10 fittings and hose. I'm trying a laser cut silicon pan gasket as well- I've always had trouble getting the drain line and oil pan to seal properly so we'll see how this goes.
As to the tune: When it's warm it seems OK, cold it's still not stable. It occaisionally stalls dropping to idle when braking from highway speeds.
Remind me again- what do I look for in the idle logs and what adjustments should I be working with? The car was pretty solid on the old injectors, so I think it's mainly injector settings that aren't quite right. Short Term Fuel Trim is cycling from 0-16.
It's usually not the gasket but instead seeping through the bolt threads. Here's what fixed it for me:
Turned up the deadband to 350 and it seems improved? Found a wiring problem in the TPS harness- it intermittantly jumps to 100 for no good reason. Gotta fix that before posting a log!
I fixed several wiring issues. I was using the plug adapters that go from DSM stock injector connectors to my new FIC injectors before, but there was definitely some wire damage on the old stock harness. I could see cracked insulation at least, and there might have been damage to the conductors.
So I ordered pigtails from FIC and installed those this weekend.
Next item to fight is excessive engine movement. I started to fab a roll stop bracket from the bell housing (I've got a 2G block, so there's no front roll stop mount on the block) but that didn't actually seem to make much difference so there are poly inserts for the roll stops on the way.
I've already got poly in the big engine mounts, I was hoping to leave rubber in the roll stops to reduce the vibration getting into the chassis, but perhaps that's just not to be. I'll find out in a few more days.
I'm still not confident that I have consistent fuel pressure, but these others are known problems to tackle first.
Update on the state of things: I've had a few different threads chasing different problems, but I think I'm now back to the previous baseline.
Clutch is back together and well sorted now, and I've swapped in a known good stock FPR from the backup car. I wanted to put in an AFPR, but I've still got my cruise control so I can't find a good place to put it. Not a "today" problem.
TPS wiring harness is repaired, and swapped out the injector connector adapters for wired-in connectors along with refreshing the wires themselves so I should have reliable signal for all of those things now. Wire to the Temp gauge sensor let go, but the ECU's sensor is fine so I'm still good to drive. I fear there is a lot more wiring repair in my future... heh...
I also added a poly insert to the aft roll stop, which was a ROYAL pain to get lined up right! Wow, what a job! But it's in, and things are pretty locked down now so I can feel the drivetrain. Excellent. That should help reduce flex problems in the exhaust.
I'm getting good help from the tuning forum is chasing my stalling and hard start problems. Adjusting the BISS to make the ICS motor settings move is a surprisingly frustrating exercise. Seems like I tighten it >just enough< to get the ISC to move off of 0, and it runs all the way up to 120. Then I have to back it off past the original spot to get it to drop from 120 and it falls all the way to zero again. Seems like there are a bunch of other things going on that maybe move the idle around so I'm chasing a moving target. For now it is moving around predictably while I drive, so I'll come back to it.
Currently running with a -32% base adjustment and 300 deadband. So far so good. I'm looking forward to getting stable enough to begin a proper tune. Having the 2.0 backup car feel "zippier" and more lively than the stroker is most annoying-- responsive low end torque is supposed to be one of the big benefits to the 2.4. :rolleyes:
Good to be back on the path of progress!
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
