Cylinder Misfire codes.
rborgia
47
May 20, 2004
Westbury, New York
I am on occassion getting Cylinder Misfire codes. It jumps from cylinder to cylinder so I was wondering if the boost is too high, would the fact I am using stock injectors cause this?
maybe too much air and not enough fuel?
I am currently running STOCK... only changes I have made are the Intercooler Pipes and the BOV.
Can the stock injectors be turned up a few percentage points? I do have an SAFC installed but correction is set to 0 across the board.
Thanks!
Rich
Are you using the right octane gas? Try new plugs and wires. Maybe some seafoam/mccc to clean out your engine too if you're feeling motivated. Those are the easiest things to try at first.
