cylinder #1 compression stroke?
The crank mark only shows TDC because it's the cams that make it compression or exhaust stroke.
If the crank mark is lined up and the cam dowel pins are at 12 o'clock with their timing marks aligned then the engine is at TDC compression stroke. You still need to make sure that the oil pump is aligned and in phase since the lower balance shaft is driven off the oil pump. See the timing belt VFAQ for the details.
