mcfeat96talon
- 50
- 51
- Jul 26, 2005
Butler,
Pennsylvania
Here it is, I put crower 272 cams in my 2g, i also installed topline revised lifters. With everything installed, cylinders 2,3,4 are excellent on compression. Cylinder 1 is low. Did a leak down test, intake valves are leaking. Removed the head took it to a machine shop, checked out fine. Re-installed everything, still low compression. found that the lash adjusters were holding the valves open once they are pumped up. I bled them all again, tested the compression and everything was great. BUT once the lash adjusters were fully pumped up again, low compression in cylinder 1, and only in cylinder 1.
Could there be some issue due to the lash adjusters recieving oil starting at #1 cylinder? I have literally tried everything I and many others can think of and still the same problem.
I have tried switching cams back to stock. Lifters back to stock, bled lifters at least 5 or 6 times, I'm at a stand still.
Any suggestions would be greatly appreciated!!!!!
