CV Joint Question
slowoldman
Feb 13, 2004
Charlotte, North Carolina
I pulled the CV_Joint and what I get is what is pictured in Green and Yellow.
Can anyone tell me how to seperate the inner shaft from the cv-joint?
I have beat on it with a hammer but no go. There must be a trick.
The inner shaft and the axle are linked by a CV cup and boot. Cut the large band on the boot and fold it back. Wala the axle will fall apart.
If I followed ya on what you were saying that should do it. Else be a bit more discriptive.
The CV spider that holds the roller bearings is held on with a cir-clip pop it off and the spider will come off by hand. The axle cup does not come off afaik.
Nanan said:
The inner shaft and the axle are linked by a CV cup and boot. The axle cup does not come off afaik.
The inner shaft (the intermedate shaft) is fastened to the CV cup on the axle by a c-clip on the inner shaft splines. You hold the inner shaft with the axle hanging down while hitting the cup with a hammer and rotating the whole thing and the two will come apart.
Steve
steve said:
The inner shaft (the intermedate shaft) is fastened to the CV cup on the axle by a c-clip on the inner shaft splines. You hold the inner shaft while hitting the cup with a hammer and rotating the whole thing and the two will come apart.
Steve
Interesting, I didn't bother to pull the cup off when I replaced the CV boot but I did have to pull the spider to get the small and of the boot on the axle shaft.
I tried hitting the cup while the center bearing was still bolted to the motor. (Probably not good for that bearing so I didn't use a big hammer:nono: ) I will try again after I pull it off. I'm getting good at pulling it. 2 Motor swaps in a year and pulled it to replace the cv-joint last weekend and none of the parts places could help me get it apart:mad: . So I put it back together so I could drive to work. I'll pull it again Friday night and see what happens.
Thanks :thumb:
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
