cv joint help
hoyboi
63
Jan 25, 2010
Newark, Ohio
guys im sorry but i have a noob question. i needed a new cv joint for my car and i ordered the one with the abs brakes. now i am really second guessing my self on whether or not my car has abs brakes iv done everything i could think or off the top of my head i checked they fuse box to see if there was a fuse but there wasnt but the guy who had the car before me completely took it apart and rebuilt and and could of not put the fuse in cause im misssing alot of fuses i also looked for the sensor but i have no idea where it is located please help me i already ordered the cv joint and i think its the wrong one :cry:
is there anywhere i can type in my vin number and find out or anything lik this
by the way its a 97 gst with front wheel drive
ok so im sorry i was having a moment after i calmed down a lil bit i remembered that about 5 months ago i replaced the vacuum line to the brake booster LOL so i figured it out plus i called the guy at napa and he said they fit both anyways
Brake booster has nothing to do with ABS. ABS should not make a difference with cv joints. If you look under the hood you would have a large (approx. 7" square aluminum looking cube) with multiple brake lines coming out of it if you have ABS.
Hope that helps.
