custom fog light brackets?
Dxc545
303
18
Feb 8, 2011
Machias, Washington
So the 96 gsx i bought a couple months ago was mid coverted to 2gb. im trying to mount the fog lights but it looks like im missing brackets for the core support to bolt onto the bracket on the fogs. I was also wondering if 2ga and 2gb core supports are also different?
Any help would be appreciated
I got a picture of the 2gb fogs, just give me a second to get it on here :thumb:
Here they are
Also, the core support should be the same
Here is the 2ga light.
ya thats what i thought, so the core support should be the same? all i gotta do is get the rest of the fog assembly?
No.
You need the core support for the 2gb.
If you use the 2ga core to instal a 2gb light, It will not work.
I don't think it would be too hard to make new ones if you had a couple of thin sheets of metal and a welder. Otherwise I would pm stangmurdera on here. He could probably find you some brackets
Sorry bro, It's not the same. I myself am looking for new 2gb brackets for my 97 GS, simply because my fogs and brackets are missing for some reason... anyway, I'm sure you can fabricate the 2ga brackets to fit the 2gb fogs somehow because the bolt pattern for the frame are the same, the only hard part woud be finding a way to make the hangers for the 2gb fogs that the 2gb fog bracket has to hold the light on the bracket. The 2ga fog brackets are elongated horizontally to hold the shape of the 2ga fogs, and the 2gb fog brackets are shorter with hangers to fit the shape of the 2gb fogs, however they share the same bolt pattern for the frame.
