Cruise control behind fuse box removal
Dsm304
142
Nov 17, 2011
Mission, Texas
Ok I googled and searched here now I might be blind and found on how to remove the cruise control part thats behind the fuse box I only want to remove that not the box on the firewall if anyone can help me or give me a link on how to do it I apreciate the help thanks guys!
To get rid of the cruise box, you would have to get rid of your cruise control. You would have to buy a non cruise cable. Its a easy install. It goes through the firewall and bolts to you intake manifold then hooks on your throttle body.
http://www.dsmtuners.com/forums/art...oving-cruise-control-installing-nc-cable.html
http://www.dsmtuners.com/forums/art...ntrol-removal-installation-write-up-pics.html
Oh ok ok so I have to remove the one in the firewall to remove the one behind the fuse box :/ I tough I could only remove the one behind the fuse box without putting the non cruise control cable well thanks ill be looking into the links I apreciate the help
You can remove just the one behind the fuse box.
What you'll need to do is to take the covers off the one mounted on the firewall (will probably need to unbolt it from the firewall first to make working on it easier) and then unhook the cable that runs to the cruise actuator behind the fuse box. Then unplug and unbolt the actuator. Easy as that.
EDIT:
Yep. I just checked the one I pulled from my car. Easy as that.
EDIT:
Oh sweet sounds easy im new to the 4g63t haha had my car less than a year so im still learning I shall be removing this tomorrow :hellyeah: thanks alot I apreciate the help you guys are the best :thumb:
I was wondering what is the black thing under the cruise control next to the fuse box the cruise control cables connect to it do I dont think I need it but to be safe do I???
Well all I wanna say is that I took it all off and it was a success haha engine bay a bit cleaner hopefully in a few weeks ill be taking all the ac components out since it went out along time ago and its just bothering there and thanks again knochgoon24 for the help it was easy as said only took me 15mins thanks!
