Critque my fuel setup
Purple_Demon
398
6
Oct 18, 2011
Chillicothe, Ohio
Power Goal: 450awhp-500awhp
Fuel: 93 octane
-Fuel Sending unit with 255hp rewired and -6an fitting welded to the top for direct AN line attachment - Have.
-255hp pump
-Fuel Pump Rewire
-FIC 1150cc injectors
-A1000 FPR
-STM Tuning Tank to rail kit
STM | 90-99 DSM FUEL TANK TO RAIL KIT
OR
Build my own kit:
-255hp pump
-Fuel Pump Rewire
-A1000 FPR
-Fuel Lab 82 Fuel Filter
EXTREME PSI : Your #1 Source for In Stock Performance Parts
- -6an PTFE Hose
JEGS Performance Products 104912 JEGS PTFE Lined Hose and Hose Ends
- Three PTFE Straight Fittings
JEGS Performance Products 104002 JEGS PTFE Lined Hose and Hose Ends
- One 90 Degree PTFE Fitting(sending unit)
JEGS Performance Products 104022 JEGS PTFE Lined Hose and Hose Ends
- Hose Ends
JEGS Performance Products 104052 JEGS PTFE Lined Hose and Hose Ends
- Fuel Rail Adapters
After hearing some feedback about smelling gas with a few of the STM Kits (HERE). I have been debating on piecing together my own kit from PTFE Hose. Both setups run about the same cost(220ish). IF anyone could throw out some feedback or recommendations it would be awesome.
Fuel: 93 octane
-255hp pump
-Fuel Pump Rewire
-A1000 FPR
OR
Build my own kit:
-255hp pump
-Fuel Pump Rewire
-A1000 FPR
- -6an PTFE Hose
- Hose Ends
The first option looks the best but I would skip the 6AN fuel pump to fuel rail line. The stock hard lines are good to about 500whp. The banjo bolt to fuel rail is the most restrictive part. Just get that fuel filter to fuel rail line with everything else listed in the first option minus fuel pump to fuel rail line.
