Fuel setup
boostmaniac
54
May 19, 2005
Us of A, Georgia
Can I run my 750 inj. with just the maft? I want to install my holset 35/40 on my stock block with just the maft,750cc,afr,dejon intake,fmic,255 walbro for about two weeks.
The answer to your question is yes, you can, but would you want to? no. My rationale is quite simple. The SAFC or MAFT (or any piggy back unit) can only go so far concerning tuning. 750 inj. are entirely to large to compensate for on a piggy back unit. The largest I would go is 660's (which I currently have) are my HI settings are hovering in the mid -30's. More rationale would be that the more correction you provide with a afc/maft the more aggressive your timing curve becomes. if you're adamant about using your existing MAFT to tune, at the very least get a chipped ECU that sets your base injector settings to 750's. This way you need only to fine tune. Goodluck with whatever you do.
Well if its only for 2 weeks then it probably wont hurt anything, just try not to "get on it" too much until you have a proper fuel setup for that large of injector (eprom chip, dsmlink etc)
I already have dsmlink, This is for the time being when I send my eprom ecu into them to socket,chip it.
