RS60 fuel setup
WillWrk4Boost
254
Jan 20, 2004
Seattle, Washington
What would sufficiant injector size be for an agp RS60 ?
Has anyone run with this turbo? What was "YOUR" set up.
Im not trying to bite on peoples setups. (collecting information)
Thank you
Devon:talon:
why do you feel this belongs in the extreme section?
Should i repost in engine tech? Or can you answer my question.
I posted here because i was confident that i would recive a knowledgeable reply from someone who would provide me with specifics rather than ask me a question that has no relevance to my post/problem.
So if you can contribute then please do so. If not then let me know what questions I should be asking.
Thanks
Devon
:talon:
Originally posted by DMS-WhiteGSX
I don't have much experience with this turbo, but from what I have read about it, I would say 850cc injectors to be on the safe side. I am sure you could get away with 750s.
With a 60-1, you can get away with 720s, maybe even 680s. The price difference isn't much. What is the rest of the setup? Personally, if I had a 60-1 and something simple like an afc, I'd just go with 720s-780s.
SETUP-
Evo lll Exh. Manifold Evo lll O2housing F.P. regulator set at 37
safc II walbro 255 hp. VRS turbo back 3" 3" dejon intake pipe gm maf K&N filter MSD dis 2 Boost gauge egt fuel press. oil press. act 2600 exact flywheel INJECTORS _______ tbd
Dual stage boost contr. hks SS bov (not venting)
Anything i might have left out that would be a must for this turbo to reduce chance of damage?
Thanks for the help
Devon:talon:
Thank you
Devon:talon:
Being a 1G, I would run a dsmchip and 850cc/min ball-style injectors. You can't go overboard on fuel systems, all it does is add to the safety margin for tuning.
www.dsmchips.com
