Creating an anti-lag via tuning?
Low Impedance
166
May 19, 2006
Cleveland, Ohio
First off, the car this is for is not the main one in my profile and NOT going to be used for drag racing. So normal forms of this arent going to work, like the built in one on the DSMlink or the "no-lift-to-shift". The car is a 1991 Eagle Talon TSi AWD 5-spd. Factory 2.0L top and bottom.
Basically the car is a very amauter level rally car. I have to run alot of factory items, but the level i am at is not really competitive and more geared towards "fun". Being that i can never leave good enough alone, is started looking into how i could make the experience a little nicer seeing that constantly varying the throttle can cause some repsonse issues with a turbocharger.
So i read about how ALS (anit-lag system) works. The therory is pretty start forward. Cause some form of combustion cycle INSDE the turbo manifold thus spinning the crap out of the turbo. Furthur reading let me see that retarding the timing (alot) while adding a degree of fuel will cause the combustion late enough where it is basically happening in the turbo manifold.
Being that timing and fuel control are standards for a DSMlink, which is what im thinking about using, i dont see why i could create an effective antilag based on throttle postion. This whole process is obvious bad on turbos, turbo manifolds and wastegates. That is why i want to be able to turn the antilag maps on and off. So under normal conditions i dont sound like hell driving down the road and not melting things. Problem is that switching maps on a dsmlink requires the laptop to be used. I am actually half tempted to use a megasquirt for this. In part because a friend is an EE and has experience using the main chip the MS uses for computation.
So here is what i propose:
1. the main variable is going to be throttle postion. When the system is working there basically will be boost at idle.
2. the actual idle of the car is going to be higher (2000+) RPMs. The reason being that the ECU normally advances timing to catch the idle to keep the car from falling on its face. Basically, im going to counter this by rasing the idle much higer.
3. Some form of switchablitly between, "off" (normal map without antilag), "1" mild antilag and "2" heavy antilag. This way there is easier adjsutability pending driving conditions.
4. as the throttle postion changes to a lesser percentage, i want the timing and fuel to adjust accordingly moving the combustion process farther into the manifold. For rally use, lifting the throttle (which for this will surely generate power loss) isnt a bad thing. Then as the throttle postion increases, the timing is added and again the fuel trim changes to bring it back to a proper power band.
thoughts?
Do you want this to happen during shifting or just whenever the turbo spools?
Ill give you an example of the situtation where this is applicable.
Say your going down a winding dirt road in second gear, rather quickly. Now, obviously, you are going to be doing alot of throttle play, especially during anyturing portions or really rough surfaces. Having the turbo constantly having to respool creates a serious lag in the power output when you are applying throttle. Having the turbo basically always spooled solves this problem.
basically it makes things like this possible
http://www.youtube.com/watch?v=XaxhTnB-eos
although, obviously, im no where near what these drivers can do, the ALS makes the car many time for driveable.
I'm not sure of the material used in our turbine wheels (ss?), but I've heard that competitive rally drivers have turbines made of inconel and spend a turbo every race.
If you are racing in a specific classification, someone may hear something funny and bump you to a different class.
Sounds like a fun project.
Ok I am with you on this,
I have been to rally races and I have also wanted to make an anti-lag system
The only way I can think of how to do this is base this on throttle position...
I hope this helps because I am coming up with this as I just read this article
What I would, like you said, make the anti-lag throttle position dependent. So when throttle is at idle or 0 , like you said, have the antilag kick in...
However you want to be able to turn this off and on... because you don't want the thing firing when score keepers are taking your time...
What I would do is figure out how to modify the throttle position sensor so that at 0 it would idle normally... however say when it is at 2% thats when the anti lag settings would be applied. Figure out then how to modify the throttle body on a switch (mechanical or electric) to switch between throttle position 2% and 0% to turn off and on the anti lag
However I don't know if this would work when you are launching from the start...
I should see or post a forum on the Rally america to see how they do it. Lots of the evos and STIs have the system. The Evo turbos can take a lot of abuse...
Rally style anti-lag systems are pretty complex and expensive to setup, it's not just tuning. It also kills turbine wheels, turbine housings, and exhaust manifold.
it maybe easier instead to go through the ignition system to create this... Figure out how to retard the ignition at a flip of a switch.
When I talked to a driver who runs the ALS, he said there were a couple of stages on his. There was three levels like mild, aggressive, and really aggressive. the level all depends on what amount of damage you want to do to your turbo. I am sure there are a couple of after market ECU that have this built in. Most people run the Drag style anti lag on dsmlink, trick is now how to get that to operate for rally mode. It would be rather difficult.
I tech alot of the rally cars at Sno-Drift rally, ALS systems are on a switch and do have more then one level. also most of the systems also have ports in the manifold it put air into the manifold when needed. This is right up top on a EVO manifold i do know with my EVO from the factory i can make about 10psi sitting still with this system but the USDM EVO's do not run the manifold ports.
(i might be wrong but in my simple mind that is how it is working.)
vs
