Crankshaft Sproket question
greysave
31
Feb 21, 2005
Williamstown, New Jersey
Are the 7bolt and 6 bolt crankshaft sproket's the same? I have a 6 bolt with the crank pulley bolts stuck in the sproeket. I wanted to know if I could use the sproket off of a 7 bolt?
I ran a vin# for a 1991, 1992, 1993, and my son's 1998 in CAPS and all 4 part numbers were the same (MD326852). You should be fine using the 7 bolt crankshaft sprocket.
Mike
Mike
So its safe to assume that they are all the same. Thats great to hear, I have a 90 motor, but I am sure that the sprocket should be the same between a 90 and a 91.
