Intake sproket
First, the timing belt will of course need to be off. Then take the valve cover off and (I think) between cylinders 1 & 2 there is a hex (like the head of a bolt) cast around the camshaft. Put a wrench on this hex. Then put a 17mm socket on the bolt in the center of the gear, and turn the wrenches opposite ways. After that, just pull the gear straight off, replace the CAS, and reinstall the cam gear.
