crankshaft sprocket Install
StevenG
Mar 28, 2011
Dallas, Texas
Does anyone know what the spacing between the oil pump and the crankshaft sprocket should be?
It's not absolutely critical; I'd say around 0.050" if I had to guess. Installing the pulley will push the sprocket to where it's supposed to be. It just shouldn't be touching the oil pump or front main seal.
When i put mine together i just pushed the sprocket back until the key was flush with the sprocket. There should be a gap between the sprocket and the oil pump as stated before make sure they aren't touching.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
