Crankshaft Pulley
blackcar08
Jun 14, 2012
Washington, Pennsylvania
Hey, I have a 2000 2.4L eclipse and am trying to remove the crankshaft pulley. There are a total of 5 bolts within the pulley (4 are small 12mm). I removed the 12mm bolts and am wondering if I have to remove the center large bolt also to pull the pulley away? I am trying to reach the crankshaft position sensor to replace.
Your car is 3G and there is a forum dedicated to your car, but the answer is:
For 2.4L - Remove the bolts that attach the crankshaft pulley to the crankshaft sprocket with a socket wrench.
For 3.0L - Remove the center retaining bolt from the crankshaft pulley.
Attach a suitable puller to the crankshaft pulley, and remove it from the crankshaft.
