420A Crankshaft Position Sensor
safirenside
170
Jan 28, 2011
houston, Texas
Which wire goes where?, I know the middle wire is power but which one is ground and which one is signal. The wires on the sensor are different from the ones on the harness. The wires on the harness are bl/wh (signal), yellow(power), and bk/gr (ground).
Aalright thanks thats what I was thinking but wasnt for sure. It was hooked up power wire to the orange wire ground to the middle and signal to the brown. I had a code intermittent loss of cmp or ckp, so I checked the wiring and it was wrong
