420A crank position sensor location?
i believe your talking about the camshaft position sensor......see pic attached. It is on the opposite end from where your cam gears are.....the closest corner of the engine towards you.
thanks, i thought that was it. Is there any way to test it without a volt meter. i lack a lot of the fancy tools
Actually that is the crankshaft position sensor. The PCM dosen't care where the cams are only the crank. It's used for fuel delivery and ignition timing.
crankshaft positions sensor is just above your oil filter. gotta crawl under the car to get to it. atleast thats were it is on my 95 gs. if you crawl in from the front of the car it will be to the upper left of the oil filter. the pic above is pointing to the cam position sensor
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
