GsxAwd2300
5+ Year Contributor
- 62
- 2
- Nov 7, 2017
Prov,
Rhode Island
So I did a lot of work including changing a manifold to a cyclone
Now the cranks but won’t start im waiting for a buddy to come by and verify spark I had my daughter hold the coil wire to ground and she said she didn’t see anything
But I heard the back fires a few times
When I crank it I don’t see the 200 rpm’s looks like nothing nothing nothing then sometimes it just jumps up
Anyways my real question is I need to charge my new ac compressor so with the cyclone there really isn’t room to get your hand to the low port with the coil installed
Anyways I stupidly had a cop laying around that needed to be wired so I wired it up and now I’m stessed I blew my ecu or something
I pulled the cover off everthing looks good check engine light comes on and goes out ect
It could also be the PTU I looked around I can’t find my original one to swap it out with
Anyways I did a boost look test and I have a major leak at the throttle body somewhere coming from behind so pretty sure that’s my problem it’s at like 5 psi
However I’m just stressed because it truly seems like I have some sort of intermittent spark issue
