koachworks
- 0
- May 22, 2002
I read in a Chilton's manual that the installation of the crank angle sensor should line up with the dowel on the cam sprocket after a cam change. I recently installed a set of 264/272 cams on my 92 GVR4 and am now getting detonation at only 15 psi of boost. The cams were installed straight up and i never got detonation before when i was using the stock cams. I may have accidentally moved the crank angle sensor while performing the cam change and may have installed it out of phase. Could that be the cause of detonation? my timing is set at 5 degrees. no boost leaks, 255 lph rewired fuel pump, 510 cc injectors, b&m adjustable fuel pressure, 16g, 2g maf, 3" exhaust, hks fmic, upgraded intercooler pipes, mines ecu.
I used to boost 18 psi with no problems. What am i overlooking here?
