Crane street cams
Ajax
822
Nov 13, 2003
Sioux Center, Iowa
Crane 0014 420A Street Cam for Turbo Engines.
#0014 Street grind for Turbo Engines Range 1500 to 6800 RPM's Intake Duration 246@006 Lift .364 inch Exhaust Duration 238@006 Lift .325inch
I got these cams from Howell automotive because I am in the process of turboing my 420a. What I am wondering about would I be able to install and run these cams without a tubo for a while b/c at this moment my funds are to low for a turbo but by bottom end kit and cams are here and I would like to install everything at once. Get it running good(broken in) and then install the turbo, so is this possible? Or should I just wait with the cams? And with these cams to I need to get my ECU adjusted or would that be fine? thanks in advance.
Yeah there in but my engine is still out since I rebuilded most of it. I should be able to put it back in by the end of this week, but I am scared shitl### to start it back up since this is my first rebuild of this magnitude. But I will let you guys know how it all went and if I still have an engine left.:thumb: ( I had to wait about six weeks for those freakin cams.)
  • Wanted 6 bolt NT water pipe
    • chrisman287
