Cracked ss brake line fitting...
eclipsed123
104
Feb 28, 2009
Newnan, Georgia
I was in the middle of installing a pair of Goodridge SS brake lines on my Talon. I accidently over tightened the fitting and it ended up splitting right down the middle. Do I have any options or am I stuck buying a pair of new brake lines? Here is a picture of the damage:
Per above, if you can put a new end piece on you might be alright with length pending. If not then you'll need a new one.
Maybe you can goto a performance shop and have them either try to fix it or fab up a new one? Or just but a new line.
I'm pretty sure any hydraulic hose shop could fix that up for you or make a whole new line altogether. If you are not sure where to find a place like that, I would contact Goodridge to see if you can order just one line.
