Brake line "AN" fitting question?
eclipsed123
104
Feb 28, 2009
Newnan, Georgia
I wasn't sure what section to post this but I'm in the middle of doing a goodridge ss brake upgrade. I got the kit used but am missing 2 fittings to complete it. The fittings that I already have appear to be "AN" fittings and threaded 1/8th of an inch (I could be wrong about that). I searched online and found out that 1/8 is converted to 2-AN but I can't find that size fitting anywhere all I see is 1/8th to 3-AN, 4-AN, ect...here is the a pic of the fitting that I'm talking about I need 2 more of the fittings in the first pic if u look at the 2nd pic you will see why I need the fittings. The kit is for a 1g and the calipers I have are 2g awd so the lines just screw into the back of the calipers and don't use the banjo bolts. See how both lines end in a female fitting I need them to end with male fittings so that I can screw the 2 lines together then screw the line into the back of the caliper.
Do you have any local welding shops or hardware stores. I would take one of those fittings down if so and see if they got it. I know our local welding shop has several boxes of those in various sizes and having parts needed for fabrication around here is null.
    • Sdcryan1
