Brake line question ...
DSM4LIFE-AWD
322
10
Aug 6, 2009
Trois-Rivieres, QC, Canada
Ok I just received my new -03 ss brake lines to start from the master and go to the non-abs proportionnal valve. Also from the non-abs valve to the front caliper hose ... I want to tuck the ss line at the top of the firewall and it seems to be at the same high than the brake fluid reservoir ... I only want to know if I can do this or I have to place the line lower than the reservoir ? Will the fluid drain back in the reservoir if the line are a bit higher than the reservoir ? You get what I'm trying to say !?
Maybe it's a stupid question but I don't want to do it twice because I can't bleed the lines ...
Thanks
Pat Farly
  • Wanted 6 bolt NT water pipe
    • chrisman287
