Brake Line Questions <Big Brake Upgrade>
JStrateger
375
6
Jul 17, 2008
New Carlisle, Ohio
Hi guys, I'm upgrading my front brakes to 2 Piston GSX brakes and I've run into a problem. Through searching I've found out that I do need new brake lines because I got 1G/3000GT Style Front Calipers.
My question is, is there any other place that sells the adapted brake lines besides RRE? I don't want to pay $105 dollars for the lines and on top of that, I only need two lines. I could probably get calipers that would fit my stock brake lines for $105. =(
Adapter Brake Lines
So you went shopping for big brake calipers on E-Bay and ended up with the wrong calipers? We have brake lines that will allow you to fit them on. They are custom so they cost a bit more than the normal kits we offer.
*Raises Hand*
As far as I know, they're the only place that sells them.
One guy that used to be on here said he had JNZ Tuning get lines made (not sure if they did it themselves or outsourced it). You might want to contact them and see what 2 lines would cost.
Call these guys...
eBay Store ? Silverstone Modification N Racing: Search results for Brakes Brake Lines.
They are in Toronto I think. I needed GSX front lines and FWD rear lines and they were able to make the rears up, so I think they fab the lines themselves or have someone close do them. They sell the normal SS braided lines that have the clear teflon/rubber coating over em, the ones I got were decent and only $80 SHIPPED for a full set of front and rear lines.
They are hard to get to answer phone...keep trying if you dont get through first time.
