Snailtrail420
- 32
- 4
- Feb 5, 2022
Halifax,
NS, Canada
I'm wondering if the port on the intake manifold right under the MDP sensor what that stock would be used for? On the vacuum diagram it says bypass valve line which I assume would mean the recirculated BOV line.
I'm just confirming as is my first DSM engine and want make sure all is perfect. Also would the thin cheapy looking style Greddy BOV line that came with the Greddy BOV I plugged in hold up fine to the vacuum air pressure?
Next I'm just wondering if the braided line I posted from the fuel regulator to the solenoid with the T connector in it. Is that where to plug my aftermarket boost gauge into, and is that a good spot for them?
I believe so though I would confirm
From intake manifold to fuel solenoid**
