femmeDSM
- 980
- 64
- Oct 31, 2004
D/FW,
Texas
Well, one set of problems down, and a new one springs up.
This time I am pretty sure it's the alternator, but I thought I would check here and see if I have overlooked something before I pull it and take it to Autozone for a test.
Here's what's going on (everything I can remember, at least):
First of all, I have gone through 3 batteries with this car. That should be indication enough that the alternator is a culprit, but there's more........
When my last battery was installed, it lasted a good solid month before I accidentally left the dome light on in the car for about 2-3 hours or so. I came out to find a stone dead battery. And I mean d-e-a-d. Zero volts. I took it back to Autozone where they placed it on the slow charger. The battery held a charge, but as soon as I got it home it was dead again. Luckily, it was under warranty and they gave me a new one.
On to symptom number 2...The car is occasionally hard to start (Takes 5 or 6 cranks to get it going some days. Other days it fires right up). While I'm cranking, I *sometimes* notice the dash lights and interior lights going dim, and the headlights turn off completely when cranking (is it supposed to do this? I can't remember if my gst did this or not?).
Symptom number 3 - the car bucks like crazy when I let off the throttle in low gears, and will die on decel. It will wait until I'm almost at a complete stop, then those telltale dash lights will start flickering. If I can catch it in time and give it gas, it will not die, but if I wait too long, it will stall. Always starts right back up though.
I have checked voltage at the battery -- with car off, it's getting 12.x volts. At idle, 14.x volts, and under load (all available accessories on) it's back to the low 12.x volts. Alternator belt is good. Alternator is new-ish. It came with the car, and I have the warranty receipt for it. I believe it is approx. 12-18 months old.
The car does not have a radio, so there is no power draw from that (unless the few wires that are still there are somehow causing a draw). I have also replaced the 80A alternator fuse under the hood.
So am I right in thinking that this alternator is going bad? I hope that's all it is, for the love of God!
