Corner Light keeps falling out???
When I used clear corners on my old 2g, the metal clip on the back of the clear corner didn't quite line up with the housing in the bumper. From what I recall, I bent the clip and ground the bumper housing slightly. When I reinstalled the clear corner, there was a very audible "click", very much like how the other side sounded when I installed it the first time. You may have to reach behind the bumper and give the housing a shove from the inside while pushing on the corner from the outside.
My clear corner does the same thing. I bent my clip and it lasted for months. but just the other day it popped back out :cry:
I Have the same problem, it's my right one. I will get to it eventually. putting a screw in there is not a bad idea.
Originally posted by Devicex
I put a screw through the inside of the bumper into the back of the sidemarker. Works well but when it comes time to change the bulbs... ;)
'that ill deff hold it.
