1G COP doable on the n/t
Stevens Talon
68
3
Apr 6, 2024
Tennessee
Is the COP (coil on plug) set up worth it on a N/T 4G63. I'm in need of a new coil and plug wires (again) and was curious if the COP works on the n/t and is it worth it to loose the expensive stock coil and plug wires. I've searched on here and couldn't find what I was looking for on info
There is definitely a benefit in running a COP on an N/A cars, otherwise none of the modern car manufacturers would have switched to COP. It's is better for spark intensity, ignition timing/precision and emissions. Also individual cylinder deactivation + simpler diagnostics no arking in the engine bay from damaged insulation. The ECU is factory tuned different in modern vehicles, to specifically run COP systems and get the maximum benefit out of them.
Are you gonna notice any difference in performance with factory ECU and no tuning?..... probably not.
You might notice some difference at higher rpm with some advanced timing adjustment, maybe running higher octane fuel, having maximum airflow and no restrictions in exhaust...but that requires aftermarket tuning support , standalone etc...
    • dsmmario
    • Canadian_CD9A
    • my98gsx
  • For sale 4G63 Six bolt cy head. Ported. SS O-rings. Ferrara valves.
    Six bolt cy head. Hand ported and flowed by Baker Cylinder heads. He started at Air Flow...
