Coolant
GRITZ
60
Jan 13, 2006
hubert, North Carolina
Is there a coolant block drain plug on the 4g63t? if so then where thanks...
Where is the coolant drain plug located on the block? i want to drain the coolant 100%
Turn the plug on the very lower right corner of the radiator counterclockwise just enough to let the coolant drain out the short hose directly under it. Unscrewing it too far will result in two drain holes, possibly a lost plug, and some discomfort if the coolant is hot and gets on you.
Oh i forgot to add that the 4g63 is swapped into my 88 mightymax truck and im using a rx7 rad.. :) the rx7 rad dosen't have a drain on the rad...So i had to take the bottom hose off..Which is the reason i was asking if the 4g63T block had a drain plug..
Merged your two identical posts. Please try to keep common questions down to one thread. Thanks in advance.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
