coolant tempature switch no wires to it?
costas14
489
Mar 7, 2008
quincy, Massachusetts
my 95 gsx automatic, it overheats but we have the ac fan so its not now, but theres no wires to the little white switch? i dont see anything cut? please help
sensor or whatever it is, its a little below the radiator cap
I believe on the 2g the temp sensor that controls the fans is located on he bottom of the radiator. That switch is bad or not plugged in. Your car has ###### been modded. I thought the water neck sensor was in the back of the housing and not by the cap. You should have a two wire plug and a one wire plug going into the waterneck. Any extra sensors are ###### there from a swap or something. Should have an vacuum switch with vacuum lines attached also but dont sweat it if they arent there.
yea my friend said theres a lot of stuff bypassed so he asked me if it was an earlier motor, but it cant be its a 95 auto gsx, you cant bolt a 6bolt up to that drivetrain, is that sensor on the drivers side or passengers? the radiator cap by the engine, thast the one im talking about how theres a bunch of sensors on it, the top one is in white and no plug is in it but someone else confirmed on here that the white thing is for the ac to turn off when it gets a certain temp
