Coolant smell and smoke
damooch
May 28, 2005
sunny, Florida
I got a question.My 99 eclipse leaks only about a cup of water a month and I cant find the leak.Also when I turn a/c or defrost to heat I smell coolant coming out of my vents for a few minutes.Also my a/c vents smoke.It doesent overheat and never has.Whats up with that.By the way I love the info in this forum.My wife thinks I am nuts.I've been reading for days ever since I found you guys........Thanks
You should get a pressure test done. If you can't rent a tester somewhere, go to a shop and it shouldn't be too much to do a quick test. That can tell you where any leaks are.
