Coolant sensor sending issues, need help
TheDeer
126
May 24, 2004
Jersey, New Jersey
Ok, car runs great, tuned perfect. New clutch goes in now the Coolant temp on the Haltech shows up at -40 [Fault]. Did the usual checked voltage from the sensor, its fine. Ran a new line right from the sensor and spliced into the haltech harness, still -40.
Has anyone seen this happen? I really hope my Haltech didn't take a poo. Also its not fun to drive a car that's fuel maps think the coolant is -40, yeah a little rich.
Its drivin me mad, any idea's or suggestions?
My coolant temp sensor took a crap and showed up at -40 degrees on the logger. They are about $26 from Satan. Make sure you get the one for the ECU and not the one for the gauge on the dash. I can't comment on the Haltech, as I don't have one, but I did have a bad coolant temp sensor.
Even worse, when I routed the entire roll of wire I used to re-run the line, was bad. Man talk about getting f'd. LOL I used another spool, and its fine, was the wire.
